Results 1 to 24 of 24
    3,362
    Industrial screw compressor thrust bearing checks
    Each brand of screw compressor has different recommendations on thrust bearing checks.
    Do you follow recommendations by OEM, or do your own thing.
    Jul 2007
    Czech
    61
    374
    Re: Industrial screw compressor thrust bearing checks
    Hi Ranger1,
    I am convinced that the compressor manufacturer has the greatest overview of what kind of repair needs to be done and after how many operating hours. I personally follow the manufacturer's recommendations.
    Josef.
    3,362
    Quote Originally Posted by josef View Post
    Hi Ranger1,
    Josef.
    Josef, Thanks,In general would that be every 30-40,000 hrs?
    Jul 2007
    Czech
    61
    374
    In general, yes, I think the same.
    Josef.
    3,362
    Josef.
    Thanks Josef
    Oct 2016
    Serbia
    110
    8
    I dont understand why the different production factory have different example,
    SAB 163 0,05 mm.
    0n frick 233 its 0.2.0max
    and on Sab 202 ,0,15
    Oct 2016
    Serbia
    110
    8
    it is crazy because we have almost same diameter.
    Sorry I must say that HOWDEN 255 try to teach 0,05 mm.
    What I think is too small.
    Oct 2016
    Serbia
    110
    8
    Concernig overhaul time everybody should have instrument for noise and heating bearings.
    To check.
    I dont have it is cost a lot off money.
    495
    21
    HOWDEN 255 has about 0.1mm to 0.18mm clearance
    3,362
    Quote Originally Posted by GHAZ View Post
    Probably referring to WRV204 0.05 to 0.075 mm 0.002” to 0.003”.
    3,362
    So would you check thrust bearings every year like manufacture recommends Howden & GEA.
    Only ones suggesting it in industrial.
    GEA wants face gap check every 5000 hrs.
    Oct 2016
    Serbia
    110
    8
    Ok my mistake , but if HOWDEN 204 try to reach 0.05mm. It is also big difference concerning other compressors.
    If others have same diameter on rotors.
    Jun 2017
    Norway
    32
    I dont think the end clearance is too critical if over-size by a few hundredths of a mm. If it's too smal i could be a problem because of rotors interfering with suction cover.
    3,362
    I think AKI refers to example Howden WRV205 standard discharge end clearance 0.05 to 0.075mm
    Frick 193 0.16 to 0.24mm.
    big difference but works apparently.
    Sep 2009
    Iran
    66
    672
    1
    In Bitzer Screw
    0.03 to 0.05 mm
    Mbc
    3,362
    Quote Originally Posted by mbc View Post
    In Bitzer Screw
    0.03 to 0.05 mm
    Mbc
    mbc, how often would you check thrust bearings on ammonia Bitzer
    Sep 2009
    Iran
    66
    672
    1
    I could not attached this file
    In Bitzer Docs.
    SW-110-2.pdf
    Sep 2009
    Iran
    66
    672
    1
    this is page 3 of that docs
  19. #19
    Sep 2009
    Iran
    66
    672
    1
    hi
    hope help
    sw-170-1.pdf
  20. #20
    Oct 2016
    Serbia
    110
    8
    Is Bitzer have that size of compressor like SAB202 or FRICK193 ?
  21. #21
    Sep 2009
    Iran
    66
    672
    1
    Mainly Bitzer works on Frion compressor
    Size up to 320 hp.
  22. #22
    3,362
    hi
    hope help
    sw-170-1.pdf
    mbc,
    Thanks, I presume similar for ammonia operation, very open recommendation, but as they say depends on system, use vibration analysis.
    Had a semi hermetic run 120,000 hours, nothing wrong, decommissioned, so who knows how long it could have run for. It was regularly checked wih VA.
  23. #23
    Sep 2009
    Iran
    66
    672
    1
    Hi Renger
    It depends of
    cleaning of system
    Oil type .
    Oil temperature
    Returning of liquid from system
    Sound and vibration analysis shows every thing
  24. #24
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, RANGER1 ... genarally following recommendations by OEM ....
    and some companies have request to check thrust bearing yearly ...
    for safety ... no unexpected downtime and compressor overhauling over night ...
    Best regards, Josip
