Results 1 to 2 of 2
Thread: BTU Calculation
21-01-2021, 04:48 PM #1
BTU Calculation
Have to bypass a heat exchanger for a brine loop ( calcium chloride) for under floor heat for a curling rink. I have pump at 200 GPM and the required outlet temp required is 4.5C on the heat exchanger is there a calculation out there for this to figure out the BTUs required? No name plate on the existing heat exchanger was using waste heat off the discharge on a mycom compressor (ammonia) at around 95C. Looking at using a hot water on demand natural gas heater for the interim or something along those lines any suggestions?
22-01-2021, 05:41 PM #2
Re: BTU Calculation
Q=mcΔT might work
