17-01-2021, 06:33 PM #1
GREE GMV IV Wired controller Z60351F
Dears
I will do startup & commissioning for VRF system by old version Gree ( GMV 4 ) .
I need the Owner manual for Wired controller Z60351F
how i can set one of the indoor unit as a Master unit , also how i can set the no of indoor units on outdoor unit PCS & dip switch ( there is no info about outdoor unit dip switch )
Thanx in advance
17-01-2021, 08:41 PM #2
Re: GREE GMV IV Wired controller Z60351F
Found asome documents that may help.
https://www.krone-klima.de/archiv/pr...8f4da9107eb43bBrian - Newton Abbot, Devon, UK
20-01-2021, 08:27 PM #3
Thanx , but hey are not English
22-01-2021, 11:01 AM #4
Hi , i have installed VRF system by AUX ,all units are working well in cooling mode, the problem in heating mode
if we start some units and the others are off , these units give a high noise , sound of hot gas in coil , if we put them on ( ON ) the noise will disappear , as i know in heating mode if the unit was off the EEV will be opened at minimum position but it has not to give this disturbing noise ?????
