Results 1 to 2 of 2
    Jan 2021
    Carel ir33 RTC Perameter
    Hi guys
    Could somebody explain the rtc Carel ir33 parameter a colleague and I were having a discussion about replacing a controller, he advised he set the defrost parameters up but but the case iced up, he set the rtc parameters as the case beside it and it's behaved since, but looking at the RTC it's not making much sense to me, the store he was working in had comms through the little carel dongles.
    Split Croatia
    57
    6,151
    36
    Re: Carel ir33 RTC Perameter
    RTC is Real time clock and is usefull for HACCP functions and if defrost is not desirable in peak loading and unloading times of cooled equipement. Other than that, it has no useful purpose to me.
