    Mar 2020
    India
    13
    Daikin brc remote
    Daikin vrv brc how to make one indoor master? Pls any one know, pls explain.
    Oct 2001
    Nottingham UK
    5,668
    Re: Daikin brc remote
    On a 2 pipe vrv system at first start up, all of the remote controllers will flash the 'On' led.
    The first controller that you press the ' mode' button will become the heat/cool master.
    On a 3 pipe system you do not have to select a heat/cool master unless you have more than 1 fan coil connected to a BS box
    Mar 2020
    India
    13
    Thanks you sir
