Thread: Daikin eev open setting
20-12-2020, 03:39 PM #1
Daikin eev pulse open setting, pls explain , thx
20-12-2020, 07:13 PM #2
Re: Daikin eev open setting
On power up EEV is driven closed to provide base setting to electronics.
Actual required EEV opening during system operation is decided by Daikin software built into the control system according to the system parameters and the sensor readings.
No user input available apart from adjusting the temperature set points.Brian - Newton Abbot, Devon, UK
21-12-2020, 02:35 AM #3
Thanks you sir
21-12-2020, 06:49 AM #4
If you want to open the solenoids/EEV's for service work.....
https://m.youtube.com/watch?v=_dZmeT6kJaY&t=11s
