Results 1 to 11 of 11
Thread: Loosing oil
    Oct 2016
    Serbia
    110
    8
    Loosing oil
    Hi guys,
    anybody have problem loosing oil from units that made in Sabroe.
    I am thinking about Sab 120,151,193,233 FRICK compressor put on Sabroe unit.
    AKI
    3,355
    Re: Loosing oil
    AKI,
    Have heard about worldwide problems coalesces not working correctly, but not replaced on any on equipment we work on.
    I think it was 1-2 years ago most issues.
    Things to look out for are correct torque setting, gasket sealing threaded rod where it goes through end cap.
    Found “0” rings from new poorly glued in, falling off when in packaging.
    Oct 2016
    Serbia
    110
    8
    Re: Loosing oil
    Sorry Ranger1 but I do not understand.
    AKI
    3,355
    Re: Loosing oil
    AKI,
    AKI, read now & see if makes sense.
    Jul 2007
    Czech
    61
    373
    Re: Loosing oil
    AKI,
    my question, the frema is an "A" -Sabroe, or Frick-sized separator.
    Josef.
    Oct 2016
    Serbia
    110
    8
    Re: Loosing oil
    Josef its A frame.
    AKI
    Jul 2020
    India
    1
    Re: Loosing oil
    Hi Aki,
    Seen almost 10 units of Sabroe have huge oil carryover, in 24 hours of operation oil level reach up to low level. Every time check coalescer filter found damaged even after 24 Hours of operation.
    Oct 2016
    Serbia
    110
    8
    Re: Loosing oil
    Hi Ultrakool,
    I am talking about units that loosing oil from first day.For example SAB 233 in 500 hours loosing 100 litres oil.
    When I check coalescer filter,pipes for return oil,block valve everything looks just fine.
    What is interesting that original SABROE 128,163,202 etc. work normal on the same unit construction.
    Oct 2016
    Serbia
    110
    8
    Re: Loosing oil
    Sorry RANGER1 now I understand.
    regards
    AKI
    Jul 2007
    Czech
    61
    373
    Re: Loosing oil
    AKI,
    not your problem, you need to complain to the coalescer filter supplier.
    Josef.
    3,355
    Re: Loosing oil
    AKI,
    A check of rack coalescer, that end caps have been glued on 100% bonded all the way around, inside out.
    - where coalescer seals on ends, does it look like a correct seal is possible.
    - If you run a lower oil level, may help.
    - Any unusual foaming of oil.
    - Internal end plate not damaged, cracked, fully welded.
    - oil return back into compressor in correct port, so no possibility oil return flow incorrect way.
    If “A” frame, does that have a coalescer eack end (Sabroe) or Frick one end, how many filters?
