    Nov 2020
    Taiwan
    Evaporator Orientation
    Does an evaporator have to be mounted vertically?
    Sep 2009
    Iran
    66
    672
    1
    Re: Evaporator Orientation
    Gas flow in DX SYSTEM ( frion or NH3) through
    Evaporators are Horizontal.
    But in wet and flooded system is Vertically gas flow from bottom to top
    In DX system with one line pipe you use it in vertical inlet gas from top with U in the end of evaporator.
    Nov 2020
    Taiwan
    So, in a traditional refrigeration circuit using r134a, it's ok?
    Sep 2009
    Iran
    66
    672
    1
    Yes
    But your system should be clean and also with R134A you should use synthetic oil with right grade depending on your temperature
    Nov 2009
    Minsk, Belarus
    171
    15
    Quote Originally Posted by Wickfut View Post
    What about water drain?
    In some places will have to think ...
