Results 1 to 11 of 11
    Jun 2020
    Malaysia
    44
    Shell and tube avaporators
    Dear friends,
    Sometimes when I open a shell and tube evaporator, I see pipes such as my sent photo attachment to help oil return to suction of compressor.
    But as you know in A/C system as result of high suction pressure oil returns to comp. easily.
    Anyway do you agree to install these pipes inside of shell & tube evaporators ? Or they do not do important job ?
    Sincerely yours.
    Somerset
    69
    4,698
    Re: Shell and tube avaporators
    Pressure and temperature are relevant!
    Lower the oil temp and you lower the its Pressure as well.
    So lowering both is a good thing is it not?
    Thanks Grizzly.
    Jun 2020
    Malaysia
    44
    Sorry , I didn't understand
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, skyboy6142
    Quote Originally Posted by skyboy6142 View Post
    Dear friends,
    Sincerely yours.
    Sorry,
    I do not understand "pipes to help oil return to suction of compressor"
    on your attached photo ....
    Why?
    Those copper pipes are on the water or glycol side and I do not see any connection
    of chilled water or glycol with compressor suction ....
    ... refrigerant is within one circuit (we call it primary circuit) and
    water or glycol are in separate circuit (we call it secondary circuit) ....
    or maybe I am completely wrong
    To me seems manufacturer is using those copper pipes for some other reason ...
    not sure which one ... but hope someone would explain all about ...
    Best regards, Josip
    Sep 2009
    Iran
    66
    672
    1
    This is in refrigeration side
    Evaporator is 2 pass design
    In running time and foming oil both pipe help to sucking oil for uper part of evaporator.
    It is good idea.
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, mbc
    Quote Originally Posted by mbc View Post
    It is good idea.
    thanks for your answer ... if this is refrigerant side (I was completely wrong)
    then those pipes make sense ...
    anyhow for me (old school) this is unusual design ...
    what about cover gasket and sealing ...
    to me, seems, bolts for cover are too much apart ...
    if you have some additional data or link for this type of evaporators
    please, post it here ...
    Thanks and best regards, Josip
    11,025
    If that is the refrigerant side then please explain how you would clean and rescale the water side?
    Sep 2009
    Iran
    66
    672
    1
    1)The cover of this side hasn't separate upside and downside. And it is one area (same as U )
    2) water moveing in shell side and shell has buffer .
    It helps water move up and down in shell side to have move efficiency .
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, mbc
    all clear ....
    but to manufacture that kind of separator must be much more
    expensive than (refrigerant in shell-water in pipes) due to baffle plates with
    holes for pipes (OK cleaning can be done chemically - but need a tremendous
    amount of chemicals i.e. full volume as shell ... for me questionable design
    Anyhow, product is on the market and people use it ...
    ... once STAL produced similar kind of oil coolers for screws
    (oil in shell with buffle plates-refrigerant (water) in corrugated pipes
    quite effective but problematic later on due to sedimentation of oil
    on pipes and causing reduced heat transfer .... big pain sometimes
    sprayed type of HE is much better solution (at least for me)
    http://www.refrigerationcomponents.c..._exchanger.htm
    We are here to discuss and think out loud ...
    Best regards, Josip
    Jun 2017
    Norway
    32
    Most of the shell and tube chillers from climaveneta has also the refrigerant side on the tube side. makes for big troubles when leak searching broken tubes.
    Sep 2009
    Iran
    66
    672
    1
    When we have wet evaporator we use shell side
    normally in dry system (DX) we use tubes side.
