Results 1 to 12 of 12
    Sep 2020
    United States
    Mitsubishi MSY-GE18NA Mr. Slim Troubleshooting
    We have a Mitsubishi MSY-GE18NA single unit Mr. Slim installed in our bedroom. This unit is for cool only no heater function. We had it installed Professionally on 09/17/2014. For the first time in 6 years were are now having problems. When we turn the a.c. on, it blows warm air. It runs for approximately 7 minutes then shuts off. The top green indicator light on the inside wall unit blinks 5 times, then it pauses and blinks 5 more times and does this continuously until I turn off the a.c. with the remote. Also, the fan on the outside unit does not spin at all during this cycle. Can anyone walk me through the troubleshooting process (voltage checks). I really appreciate your support. Thank you, Tommy.
    Sep 2020
    United States
    Re: Mitsubishi MSY-GE18NA Mr. Slim Troubleshooting
    These are the current remote control settings. With these settings the a.c. runs for 6 minutes then it turns off.
    The green indicator light blinks 5 times then pauses for a second, then blinks 5 times then pauses and does this continuously until I turn the a.c. off with the remote control. Again, the fan on the outside unit does not spin at all. Thank you, Tommy.
    Feb 2008
    502
    it sounds like a faulty compressor
    Sep 2020
    United States
    Is there a way to test the compressor? The large fan on the outside unit, is it ac or dc current that operates it? I need to test this fan as well. Thank you, Tommy.
    Here is a copy of the unit service manual which gives the fault diagnostics.
    Hope this helps, start around paragraph 9.2
    https://www.mitsubishi*echinfo.ca/sites/default/files/SH_MS%2528Y%2529%2528Z%2529GENA_OBH548D_16.pdf&ved=2ahUKEwjTw4vekuvrAhWtRxUIHSngBJgQFjABegQIBBAB&usg =AOvVaw0EY7gub0zERS9euoHDcKfc
    NOTE Because of the forum language filter in the above link you need to change the * for the letter "t" as mitsubish itechinfo contains s h i t which gets turned into ****.
    Last edited by Brian_UK; 15-09-2020 at 01:45 PM. Reason: Forum rules getting in the way ;)
    5,667
    The link doesn't seem to work Brian
    Did you replace the * ?
    You need to cut and paste.
    Sep 2020
    United States
    I tried to cut and paste the "t" it didn't work.
    Okay then try what I did on your behalf, search the internet for your units service manual like this ...
    https://bfy.tw/P4Rd
    Look for the Mitsi......techinfo.ca pdf file offering.
    Sep 2020
    United States
    Brian, I googled the model number. I was then able to get to the Service Manual. Really not that user friendly. Anyway, it says if your indoor upper green lamp indicator blinks 5 times and then pauses for a few seconds, then does it over and over. It says the cause is with the Outdoor unit. The outdoor unit has a system abnormality. It then says to Refer to "How to check the inverter/compressor. I know that the inverter is the outdoor circuit board. Have no idea what the compressor looks like or how to check it. I took the top and front covers off from the outdoor unit as shown in the pictures I have posted. Any suggestions from here? I up righted the picture, now I don't know how to delete the picture that is side ways. Thank you, Tommy.
    Feb 2008
    502
    you need to call a engineer
    Sep 2020
    United States
    Yes, I agree with you on that. I have to talk this over with my wife. I want to thank you all for your support. Stay safe, Tommy.
