Results 1 to 8 of 8
31-07-2020, 12:01 PM #1
Split AC wont turn on - need help for diagnostic
Hi everyone.
I have a split ac (about 6 years old) that started leaking about 2 weeks ago but I realized it came off the bracket in the back so it wasnt level. I fixed that and it worked fine since then but now it wont turn on at all.
Is there a way to perform some basic validations before I call a contractor?
Also, if one of the units is defective, can the contractor swap just the inside or outside unit or it has to be the whole system?
Thanks a lot.
31-07-2020, 01:09 PM #2
Re: Split AC wont turn on - need help for diagnostic
Check the power supply to both indoor and outdoor units.
Remote controller operating correctly, batteries, wires.. ?
Did your remounting works cause any damage to the pipework at all, maybe refrigerant leakage?
It's hard to diagnose an unknown and unseen system from a distance.
Hopefully and broken/failed parts should be replaceable depending on spares availability.Brian - Newton Abbot, Devon, UK
10-11-2020, 05:42 AM #3
Hi ,
You need to check the all component of ac . after that ON your ac. and call customer care to fix the issue.
11-12-2020, 07:56 AM #4
hi,
you need to check all the component of Split AC. after that check the cable and then start.
11-01-2021, 12:36 PM #5
If it started leaking (I assume you mean the refrigerant) then you will need a professional to attend to carry out a leak repair and recharge
26-04-2021, 12:38 AM #6
Based on my experience, the contractor only replaced the things that needed to be replaced, I highly suggest you hire a reputable AC contractor to be sure that the repair would be done properly. I personally recommend that you get an air conditioning maintenance plan from a professional AC service provider to get your unit checked and serviced regularly. This is because that issue might've already started a long time ago and it could've been easily prevented if it was checked and serviced by a technician as small issues like the bracket coming off would've been detected and fixed early before it turned into a more costly repair like the one that you're experiencing right now.
04-05-2021, 05:38 AM #7
If your AC unit won't turn on, the first thing you should check is if there was a blown fuse or a tripped breaker. There's a good chance that the problem is a tripped breaker if the circuit was overloaded. However, it is also possible that a power surge caused your air conditioner to blow a fuse or trip a breaker.
Hope it helps
JoeLast edited by frank; 04-05-2021 at 07:45 AM. Reason: Advertising link removed
04-05-2021, 01:02 PM #8
As no response from original poster since last July this tread is now closed.
