31-07-2020, 10:38 AM #1
what to do when temperture over 50 C in the shade
hello
with temperature rise to 50 C or more in the shade how about in direct sun may be 54
most aircondtioner effeicinct decrease
except one with outdoor unit has double raw
while one with one raw compressor overload
but what make worse is electric power shoratge
come 2 hours cut 4 or more sometimes
sometimes in 24 hr we get power 6 hours only
so we depend on generator 11 amper so no Air conditioner just ceiling fan which make it worse but better than nothing
photo from my car in the shade at 4 pm
https://www.mediafire.com/file/2jfo0...1641;.jpg/file
Power consists not in being able to strike another but in being able to control oneself when anger arises
31-07-2020, 11:54 AM #2
Re: what to do when temperture over 50 C in the shade
Hi Kefah, good to read you.
If you have spare water then a spray over the condenser coil can help.
Without power then you are stuck.Brian - Newton Abbot, Devon, UK
01-08-2020, 08:04 AM #3
01-08-2020, 02:38 PM #4
01-08-2020, 07:57 PM #5
What underground temperatures do you get?
Could you use a sort of reverse ground source heat pump. Or even just a pumped water loop with heat exchangers.
Are there any fluids that increase in density with an increase in temperature?Last edited by seanf; 01-08-2020 at 08:01 PM.
02-08-2020, 01:35 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
02-08-2020, 11:08 PM #7
today weather is better
just 46 CPower consists not in being able to strike another but in being able to control oneself when anger arises
