Thread: LG Condense
20-07-2020, 08:52 PM #1
LG Condense
Hi All,
Could anyone help with this please?
An LG split that I installed last year has started dripping water and spraying the odd drop out of the fan blower. The unit is level, the drain is clear and running as it should. The water seems to be gathering in the fan housing and then either getting flicked out by the fan or dripping out. Tried setting temp to 22 and it still does it. Can anyone shed any light on this?
Many thanks
20-07-2020, 10:04 PM #2
Re: LG Condense
Has the unit been cleaned thoroughly, fan, drain pan, coil etc?
Is the coil icing up (refrigerant leakage)?Brian - Newton Abbot, Devon, UK
21-07-2020, 08:37 PM #3
10-11-2020, 05:22 AM #4
Re: LG Condense
Hi ,
you need to call customer care and tell the problem .your split ac problem will solve.
