Thread: Best way to charge POE oil
17-06-2006, 10:03 PM #1
Ok so I flushed a compressor out with IsoPropyle alcohol to clean it up, vacuumed it to ensure it was dead dry and now it comes to putting in the new oil. So what is the best way?
Should I just measure it in a measuring cup and funner it in quickly then Immediately vac the system down, or should I use a dip tube and vacuum pump to suck the ol in.
I was thinking of removing the rotolock valve and just pouring it in then reconnect it, vac and then circulate it for a while under vacuum. Please keep in mind as of yet I still have little equipment for the oil handling stuff.
FYI I think this forum needs a dedicated section all about oils and stuff to do with it
17-06-2006, 10:07 PM #2
Re: Best way to charge POE oil
Hi MG you didn't say whether it was a hermetic or semi.
17-06-2006, 10:55 PM #3
Oh many apoligies. This is a Hermetic system.
http://www.ocforums.com/showthread.php?t=451006
http://www.ocforums.com/attachment.p...4&d=1146945644 < Direct to pic
if the direct link tot he pic does not work it is post #71 Pic 2
Copeland compressor oil charge?
By Larry2 in forum Air ConditioningReplies: 5Last Post: 20-09-2006, 01:04 PM -
Calculating refrigerant charge
By Consultant in forum RefrigerantsReplies: 2Last Post: 10-05-2005, 03:39 PM -
Help with charge calcs
By dallan in forum FundamentalsReplies: 4Last Post: 04-01-2005, 07:11 PM -
Total System Charge
By dallan in forum FundamentalsReplies: 1Last Post: 27-12-2004, 08:18 PM -
How do you charge a car A/C
By dude in forum Air ConditioningReplies: 21Last Post: 02-04-2004, 09:36 AM
