Thread: Bleed hole
    Jun 2020
    Malaysia
    44
    Bleed hole
    Hi friends,
    What is bleed hole on expansion valve and what is advantage of expansion valve with bleed hole ?
    Thanks.
    11,024
    Re: Bleed hole
    The bleed hole allows the pressure to equalise from the high to low pressure side of the valve when the compressor has stopped. It makes the restart of the compressor easier for the motor especially low back pressure compressors.
    There is also a special bleed hole to increase system capacity.
    See page 12 of this Sporlan technical paper, 10-9.....
    http://solutions.parker.com/Sporlanliterature
    Jun 2020
    Malaysia
    44
    Re: Bleed hole
    Thank you so much
