Thread: Daikin R32 MultiSplit Issue
19-06-2020, 12:42 PM #1
We recently replaced a customers old R22 Inverter Daikin Multisplit with a Brand new R32 Inverter System.
The customer has complained that, if using one of the 3 units on heat, the other two indoor units coils are heating up/cooling (not switching on, but refrigerant is flowing to them).
We have not attended yet, no other multi splits we have installed have worked this way.
Thoughts Welcome Please?
TM
19-06-2020, 09:49 PM #2
Re: Daikin R32 MultiSplit Issue
Fujitsu multi's do the same thing. Hot gas goes to each coil and if the EEV of unused fan coils are closed the oil can get trapped. Unused fan coils have the EEV slightly open to avoid this so the coil will get warm as a result.
20-06-2020, 11:59 AM #3
Many Thanks
23-06-2020, 11:20 AM #4
23-06-2020, 10:57 PM #5
Not sure exactly where it’ll get trapped and thinking about it, if the EEV was closed then theoretically there will be no flow therefore no carried over oil?
I’m guessing oil concentration will be somewhere in the hot gas pipes near the outdoor unit and oil would sit in any low parts of the pipework .Last edited by Tayters; 24-06-2020 at 12:25 AM.
12-09-2020, 04:21 PM #6
