Results 1 to 1 of 1
03-06-2020, 08:54 PM #1
Trane Rtwa Chhn compressor oil issues
Hi , I have recently carried out a repair on an Rtwa which has 2 x chhn 060 compressors. Repairs was replacing compressor center O ring. Replacing oil filter and oil housing gasket.
I also replaced the discharge end plate gasket.
I am now experiencing oil issues within compressor. There is no oil safety on these. I have checked the oil filter and oil cover gasket was installed correctly. Also the compressor center O ring replacement was straight forward following the IOM.The only other gasket changed other than suction and dischage valve gaskets was the first gasket behind discharge end plate which has the oil galleries. I have since noticed there is a 5mm metal plate behind that gasket which has a second gasket. Would anyone have a compressor manual for a chhn 060 with parts breakdown to see where the problem lies. I am hoping I have been sent the right gasket and still trying to get info from Trane.
