    Jun 2006
    TX
    44
    8
    compressor running dry
    i have a general question. What happesn say when u have a leak and all the refrigerant leaks out and then u run the compressor.
    What will happen? Will this damage the compressor
    May 2006
    uk
    Re: compressor running dry
    pending on how long it has been running, remember the compressor needs cool gas down the suction to keep the windings cool. i have known compressors to run and cycle on the klixton until an engineer has arrived but over a short time the compressor will be damaged
    May 2006
    uk
    and yes normally the sight glass should be clear but you must attach your gauges to find out if the system is completely void of refrigerant
    Sep 2003
    ISRAEL
    72
    4,248
    there should be a low pressure control to protect the compressor from such events.
    Chemi
    Jun 2006
    TX
    44
    8
    thanks for the replies
