    Jul 2017
    Qatar
    44
    34
    economizer line/subcooler line
    Hi guys,
    I was checking piping diagram of "economizer" for screw compressors and "sub-cooling" line of 2 stages compressors.
    Both of them were same and both of them is for subcooling liquid line and also increasing mass flow of compressor …… .
    But why on screw compressors we call it economizer line and on 2 stages compressors for blast freezer we call it sub-cooler line or I have mistake ?
    Thanks.
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: economizer line/subcooler line
    here you can read a lot about economisers/sub-coolers ...
    http://www.refrigeration-engineer.co...earchid=699656
    about 7 pages with posts regarding economiser/ sub-coolers etc ....
    if above link is not working in search window write ... economiser ....
    ... actually economiser line is a special port on compressor which is in function only when compressor capacity is above 75-80% ... below that capacity eco port is on the same pressure which we have on suction on that system ...
    economiser main purpose is to increase system capacity up to 20%,
    but increase of input power is only 8-10% ...
    Above is STAL - STALOMIZER with some explanation ...
    here is some good link ... I hope ;-))
    https://www.swep.net/refrigerant-han...systems/asdf4/
    after reading if you need some additional help, please, do not hesitate to ask ...
    Best regards, Josip
    Jul 2017
    Qatar
    44
    34
    Quote Originally Posted by Josip View Post
    Best regards, Josip
    Thanks a lot for your help.
