Results 1 to 9 of 9
    Feb 2020
    Pakistan
    27
    Environmental Data Selection
    While designing a new plant, what should be selected values of dry bulb and wet bulb temperature while selecting an evaporative condenser for industrial application operating 24/7. ASHRAE has given its environmental data in Fundamentals as well as below link.
    http://ashrae-meteo.info/index.php?l...%27&wmo=416410
    Generally what environmental conditions are chosen for such application, 0.4%,1%,5%? Are they chosen from design column or monthly column.
    Feb 2020
    Pakistan
    27
    Re: Environmental Data Selection
    Can anyone share thoughts on this particular matter
    Nov 2009
    france
    64
    223
    Hi Rize 1159,
    the usual value chosen by Baltimore, if no request from customer, is the higher WB value in 2% monthly time.
    Sep 2008
    Canada
    811
    At 0.4% the difference is not significant 29.3C and 30.3C. What is going to be your condensing temperature (pressure)? This is the most important issue.
    3,355
    The piping is just as important as the correct selection of the equipment in multiple condensers.
    This is a good document.
    https://www.evapco.com/sites/evapco.com/files/2018-02/EvapcoPiping%20EvapCond131A.pdf
    Feb 2020
    Pakistan
    27
    Quote Originally Posted by Segei View Post
    Without considering your wetbulb, how can we decide condensing temperature and pressure?
    Sep 2008
    Canada
    811
    Look at this bulletin from Evapco https://www.evapco.com/sites/evapco....bulletin_0.pdf
    Assume that design wet bulb temperature is 86F(30C). Heat rejection factor can be chosen as 2.47 and condensing temperature will be 95F(35C). If you choose heat rejection factor 2.25, condensing temperature will be 96.3F. Heat rejection factor is the most important part to achieve required condensing pressure. In this case I would choose 2.47. This is better for energy efficiency and it will better keep condensing pressure when heat transfer surface deteriorate.
    Mar 2009
    U.S.A.
    320
    You answered the fundamental question yourself: A food processing plant operating 24/7 cannot be subject to refrigeration shortages 5% of real time: And you don't know by what extent its going to be short without looking at the 1% and .4% values. If the 5% and 1% are wide spread, say 4-deg C. there is going to be a considerable proportion of real time when your industrial operation is going to be limping badly....On the other hand if this is a cold storage there are certain things that can be done when the weather gets that way to decrease load, but thats not practical with an active process...In most processes, the whole operation becomes a sinkhole for money when the throughput drops even marginally.
    Jul 2006
    73
    865
    26
    I have been through this before.
    I asked for a quote on a new condenser that operated a Spiral Freezer. On hot days the Screw Loading Percentage would back off due to head pressure (Motor Overload)
    The Contractor insisted it was not worth the money when we only occasionally had an issue.
    We also had a small Nitrogen Tunnel we used for overflow. A Vice President decided without consulting anyone that we should install a larger Tunnel. (Which worked well, until we got the bill for the Nitrogen!)
Tags for this Thread
