Thread: Ice slurry pumping
16-06-2006, 03:12 AM #1
Ice slurry pumping
Hi, anybody has experince in pumping slurry of ice+water? or Know where I can find any bibliography about this?
Regards,
Volnei
19-07-2006, 01:17 AM #2
Re: Ice slurry pumping
I worked for several years on systems that used ice-water slurries. We could pump slurries of up to 30% ice with centrifugal pumps. The pumps had open type impellers.
The National Research Council in Ottawa, Canada did some research into this back in the early ninties. The project was headed by a man named Gupta.
19-07-2006, 10:13 PM #3
Originally Posted by Volnei
I work for a company in this field. We use open centrifugal pumps up to 20% but over that we use gear pumps in stainless steel. We use Lowara pumps in stainless steel up to 20%.
Pumping refrigerant into evap?
By Larry2 in forum Air ConditioningReplies: 8Last Post: 18-07-2006, 10:43 PM -
problems with ice slurry production by spraying water in a vacuum chamber
By goodluck99 in forum Trouble ShootingReplies: 6Last Post: 16-04-2006, 01:27 AM -
Determining the actual pumping efficiency
By shogun7 in forum TrainingReplies: 0Last Post: 24-01-2005, 02:13 AM -
liquid refrigerant pumping
By shogun7 in forum New TechnologiesReplies: 17Last Post: 08-09-2004, 10:36 PM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM
