Thread: Dixell Hot Key ?
11-02-2020, 06:31 PM #1
Dixell Hot Key ?
I just wondered if anyone has had any experience of using the Dixell Hot Key at all, I have just purchased an XW60K pcb only version controller with a T620 head unit and a Hot Key 64 to setup in the workshop, now the manuals say that I can upload and download settings from the key, however when I insert the key and press the up button as I am supposed to do I get an "err" on the display which I presume is an error, if anyone can help I would very grateful.
thanks In Advance
Stuart
11-02-2020, 08:15 PM #2
Re: Dixell Hot Key ?
you use the key to download from a controller and then upload onto a new controller
11-02-2020, 09:06 PM #3
Hi Martin,
Yes I know what it is supposed to do but it isn't doing it
cheers
12-02-2020, 12:09 AM #4
Is there a supervisor password or similar to be set first?
12-02-2020, 09:20 PM #5
Ok I have it sorted now thanks, the controller that I have does not use the type of Hot key that it is supposed to, ie Dixell say that the Hot key 64 should be used but in fact it is a Hot key 4k that works if anyone is interested
thanks
Stuart
Thanks for your input guysLast edited by acestu; 13-02-2020 at 06:29 PM.
