Thread: What kind of valve is this?
15-06-2006, 03:44 PM #1
Can anyone identify this valve? It has three staggered threaded 1/4" ports, a knob that pulls in and out, and is plugged at the other end. The body is 3" long and 1 1/2" in diameter. There are five of these used for manual capacity contol on a Grasso compressor.
PatrickLast edited by flasah; 15-06-2006 at 04:43 PM.
15-06-2006, 09:15 PM #2
Re: What kind of valve is this?
Hi Flasah
I can tell you what it is but I can't tell you where to get it except Grasso.
Its a three port hydralic diverter valve.
You can repalce it with any valve manufacturer provided the valve is compatible with the refrigerant and the oil being used. The pressure shouldn't be a problem say 8.5 bar on a grasso, much lower than 120 bar on a hydralic system
Kiind Regards AndyIf you can't fix it leave it that no one else will:rolleyes:
15-06-2006, 10:47 PM #3
Andy,
Thanks for the help. Now, hopefully, I'll be able to find where to get one.
Patrick
Scotsman commercial H2O inlet valve
By fullcourt in forum Trouble ShootingReplies: 9Last Post: 25-04-2006, 11:41 PM -
Need a correctly sized valve
By Abe in forum CommercialReplies: 2Last Post: 26-10-2005, 08:42 PM -
pressure drop between expansion valve and distributor
By aygul in forum Technical SpeculationsReplies: 10Last Post: 22-01-2004, 09:47 AM -
TEV with MOP: how to keep valve body temp above bulb temp?
By DaBit in forum FundamentalsReplies: 5Last Post: 16-10-2002, 12:38 AM -
Valve "Hunting"
By Abe in forum Trouble ShootingReplies: 20Last Post: 21-01-2002, 12:29 AM
