    May 2011
    India
    38
    106
    13
    Time Factor when determining AC capacity
    When designing a room for 23 deg C, against the ambient of 52 deg C, how can we estimate the time required to cool down the room to 23 at the first place?
    Similarly, the other way around for heat gain.
    Let’s say the room is at 23 deg C. If the AC fails, how long would it take for the room temperature to shoot up?
    How can I take into account of time in heat transfer? LMTD?
    Sep 2009
    Iran
    66
    672
    1
    Re: Time Factor when determining AC capacity
    When you design air condition system
    Your load is :
    Losing heat from building
    Heat comes from machinery
    Heat comes from people are working
    Heat comes from changing weather
    Heat comes from lighting system
    Normally it is for one hour
    3,355
    Didn’t read fully, maybe this helps.
    I would have thought insulation, windows, humidity & mentioned in previous posts could influence things.
    52 degC very high for indoor & outdoor unit, which would have to be checked out.
    https://www.google.com.au/amp/s/www....ons-d_747.html
    https://www.physicsforums.com/thread...g-time.707354/
