    Jun 2008
    london
    63
    115
    E4 code on AUX air conditioner
    Hi lads
    i am having problem with e4 code on a new aux split system. i do not know who installed it , it does not look like a pro job. i want to change the evap sensor but feel it might be the board. any idea how to fix it?
    Oct 2008
    newbury
    1,444
    37
    Re: E4 code on AUX air conditioner
    Yes call an engineer
    Good luck
    Jun 2008
    london
    63
    115
    Both coil and room sensors are okay.
    Please do not send smart remark .
    Oct 2008
    newbury
    1,444
    37
    Quote Originally Posted by sork View Post
    Good luck.,....,
    Aug 2007
    Russia
    138
    21
    It seems to be a Drainage system failure
    Jun 2008
    london
    63
    115
    Thanks Narkom .
    Jun 2008
    london
    63
    115
    、E4 by chigo states: Check whether the winding resistance andoperation current of the compressor are normal.2、Check whether the high and low pressure is normalwhen the unit is running.3、Check (whether the coil pipe sensor is normal)whether the contact of the inserter on the circuitboard is well, the coil pipe temperature sensor isfixed, the evaporation of the indoor unit is well,the key is to check the evaporator temperaturedetected by the coil pipe temperature sensor hasreached the cooling or heating temperature.4、Check whether the surface of the condenser is toodirty, it should be cleaned when it is too dirty.5、Check whether the capacitance of the outdoor motorand the fan is damaged, it should be replaced whenit is damaged.6、If the above items are normal, the electric controlboard should be replaced.
