Results 1 to 13 of 13
    Oct 2008
    newbury
    1,444
    37
    New LG CT24.NP2 split condenser very noisy
    chaps we have just fitted a cassette system on the new R32 . Started up and by Christ the outdoor unit compressor is bloomin noisy. Looking at the internals the insulation of the compressor is very shoddy and half hearted. I measured 68 db my the unit and the client is saying it's not acceptable.
    Outdoor Unit
    Compressor Type
    Rotary
    Sound Level (H) - Cooling
    48 dB(A)
    Far far louder than the old Fujitsu 7kw condenser which came out
    I ma going to have to put additional sound proofing around the compressor and housing to try to reduce it as much as possible
    however a thought occurred to me, is there a night mode I can put the system into to help. Can't find it in the manual
    TIA
    richard
    11,024
    Re: New LG CT24.NP2 split condenser very noisy
    Hi Richard, I've had some contact with back2space who has had exactly the same noise problems. LG said that they 'under-designed' the compressor insulation.
    Perhaps contact him to get his comments.
    Oct 2008
    newbury
    1,444
    37
    Ok thanks. I looked at the compressor and ypy could clearly see parts of the body not insulated. I had already told the client i i tend to return to add extra sound deadening .
    LG "its good but its not right"
    only been fitting LG since daikin hiked their prices way above the compitition a 3.5kw wall mounted is 100 euro more than a fujitsu for example ie 25% dearer
    nd there are silly stupid design flaws which if they had just thought another 5 minutes would have made their kit excellent
    As it is i spend too much time shaking my head
    Feb 2008
    502
    21
    try fitting tosh much better than lg
    Oct 2008
    newbury
    1,444
    37
    Quote Originally Posted by martinw58 View Post
    I have fitted a lot of toshiba during my time in uk and i know all the makes avaiable and loads the uk have never heard of too but You need to understand the local market here before offering alternatives as its not just like the uk here availability and after sales is so different
    Oct 2008
    newbury
    1,444
    37
    Returned to the site and fitted 2 old jackets which has made a massive difference . We were amazed by how effective they were.
    Sad to say it seems the koreans are still miles behind Japan for quality. They always seem to cut corners and be sneaky with what they produce
    Feb 2008
    502
    21
    i thought you was in Newbury uk
    Apr 2008
    Southampton, England
    49
    1,023
    36
    Hi Richard.
    Either LG have taken a dive in quality (if that was possible :-] ) or that's a dud unit. Even the cheap units here with the 'powered by Toshiba or Panasonic' are quiet, much like any of the main brands to be honest. These are all inverters though so I'm guessing yours is fixed speed?
    Last fixed speed I looked at was a 407C LG a few months back and that wasn't overly noisy, just normal what you'd expect to be honest.
    Sure you're on it, man of your calibre but just putting it out there that compressor not got any transit fixings still in place or a bolt/similar wedged under it?
    Cheers,
    Andy.
    Oct 2008
    newbury
    1,444
    37
    No Tenerife.
    Oct 2008
    newbury
    1,444
    37
    Quote Originally Posted by Tayters View Post
    Hi Richard.
    Cheers,
    Andy.
    Fixed speed were banned in spain a few years back. Inverters only
    Its possibly a dud but brand new and if backspace had issues then we are not alone. The level of compressor insulation is a joke but if on a roof it would probably not be questioned. This is inside so its really loud.i had thought about transit fixings etc but nope all clear.
    Its obviously just cost cutting because as i say once we put extra insulation around it quietened it to an acceptable level. Just isnt right.
    To be fair having installed as few 2.5 kw up to 10kw lg they are all noticeably louder than the daikin equivalents..
    Oct 2008
    North East
    1,050
    Hey Richard,
    Having exactly the same issues with an MU4R25 U40 - See below videos:
    https://www.youtube.com/watch?v=QnFE-XPqhYM
    https://www.youtube.com/watch?v=0TXQtfMhtFo
    https://www.youtube.com/watch?v=wecG64VZ32Q
    https://www.youtube.com/watch?v=S8lPQVfT3rs
    https://www.youtube.com/watch?v=ftRvpXZzfy8
    https://www.youtube.com/watch?v=-l1KnuQVCfU
    LG initially offered to supply a new compressor under warranty however I was not happy with this on a brand new unit. The previous unit only 2 years old was R410a and was the exact same model and capacity how ever this one one is R32 and noisy as hell.
    LG have even been out and agreed there was an issue. They initially said that the insulation inside the casing (not the jacket some sound deadening material that is stuck to the panels inside) had been under designed. EVen though it was the same material as on the R410a equivalent. Then they came back and had been told the wrong information by the LG EU and that they were not aware of any issues on this particular model. It was one of the smaller outdoor units that had a recognised issue with the insulation.
    Oct 2008
    newbury
    1,444
    37
    Ours was much louder from 10m you could hardly hear yourself speak... the client complained so whilst we discussed it with LG, we wrapped the compressor with two old jackets from other old condensers and it quietened it round down to an acceptable level. We then had LG out who said "it's the fan noise" I told them no it's only this quiet because we have wrapped it properly. I didn't fancy taking it all out so they could hear it because if it never went back again as quiet I'd kick myself..As I said above you could actually see the compressor body with the insulation in place and the matl they wrapped it was like cheap carpet not sound deadening material ..There is no way they could have tested it and signed it off as 47db and kept the same jacket. I suspect they test it with one jacket to get the rating and manufacturer it with a cheaper version..
    The reputation of integrity of LG just doesn't seem to get better. cheap Shysters . IMHO.
    Oct 2008
    newbury
    1,444
    37
    Quote Originally Posted by back2space View Post
    Hey Richard,
    so what did they actually do about it?
