    Mar 2007
    CYPRUS
    63
    Refrigerant compressed air dryer
    Dear Colleagues
    In a refrigerant air dryer R22, I would like to replace the High Pressure Switch, setting in 28Bar (CUT OUT), with a thermostat and I would like to know at what temperature must be set (CUT OUT).
    Thanks a lot.
    Best Regards
    11,025
    Re: Refrigerant compressed air dryer
    Set the same temperature as the original pressure setting was at.
    Same switch, different dial.
    Aug 2007
    Adelaide Australia
    70
    562
    Hi kaskiris
    If it is a HP safety I would not replace it with a thermostat.
    Paul
    Born to fish, forced to work
    Feb 2008
    505
    why replace a high pressure safety switch with a thermostat
    11,025
    Quote Originally Posted by martinw58 View Post
    Probably because it has failed and he doesn't have a spare available on the island.
    Aug 2014
    75
    508
    This sounds a very strange idea and potentially dangerous . For a thermostat to work, 1) it’s bulb would need to be fitted in one particular position on the system ,2) the bulb would need to be insulated from air movement etc , 3) the thermal lag of the thermostat would need to be taken into consideration.
    The thermostat setting would be approx 70 deg C . provided the bulb was fitted to the correct position in the system.
    In theory an HP pressure switch will work anywhere on the high side of the system from the discharge pipe through to the liquid line. A thermostat though would only work correctly in one area only .
    Perhaps Kashmiris can tell us specifically where he would fit the thermostat bulb as this would need to be correct for correct functionality of the stat to take place.
    Is Cyprus really that isolated you can’t get parts overnight, or in a few days?
    http://etapol.com/index.php/thermostats-controls
    Feb 2008
    505
    dose Cyprus come under f gas regs with regards to working on old R22 equipment
    11,025
    Is the OP going to reply or are we wasting our time here
