    Mar 2016
    IRAN
    182
    9
    What is your opinion ?
    Dear Friends,
    What is your opinion about installing evaporators beside of each other in this shape (photo below) against installing in a line or installing opposite of each others.
    Installing such as below does effect on evaporators heating load ? Is it true or not ? What would happen if we install evaporators in this shape ?
    Sincerely yours.
    Oct 2003
    5,630
    Re: What is your opinion ?
    Quote Originally Posted by A.Mortezania View Post
    Dear Friends,
    Sincerely yours.
    The right one will take the already cooled air to cool it down, decreasing its DT over the coil. The right one will have a lower capacity than the left one.
    Mar 2016
    IRAN
    182
    9
    Thanks for sharing your opinion.
    ireland
    1,450
    So long as they don't run together it shouldn't be an issue, but as peter says, one will starve the other if they run together.
    3,856
    Also the light fitting is the wrong way round, it will negatively influence the coanda effect.
