Thread: What is your opinion ?
19-06-2019, 07:32 PM #1
Dear Friends,
What is your opinion about installing evaporators beside of each other in this shape (photo below) against installing in a line or installing opposite of each others.
Installing such as below does effect on evaporators heating load ? Is it true or not ? What would happen if we install evaporators in this shape ?
Sincerely yours.
20-06-2019, 09:32 AM #2
Re: What is your opinion ?
20-06-2019, 08:23 PM #3
22-06-2019, 06:29 PM #4
So long as they don't run together it shouldn't be an issue, but as peter says, one will starve the other if they run together.
23-06-2019, 05:42 PM #5
Also the light fitting is the wrong way round, it will negatively influence the coanda effect.
