Thread: What is this ?
    Mar 2016
    IRAN
    181
    4
    What is this ?
    Hi Friends,
    Would it be possible tell me what is this part inside of white circle and inside of BITZER semi-hermetic compressor ?
    Sincerely yours.
    2,714
    30
    Re: What is this ?
    Oil return system & gas equalizing maybe, part 86 & 103
    https://eparts.bitzer.de/index.php/m...C33804%2C33805
    Aug 2014
    70
    458
    Re: What is this ?
    It’s a Venturi type device to remove oil from the motor housing back into the sump
    2,714
    30
    Re: What is this ?
    https://eparts.bitzer.de/customer.ph...C32655%2C32656
    I didn't realize my link did not show correct information of part 86 & 103
    Venturi, I'm not sure about that, as would it not pressurize sump, has to use discharge pressure to make venturi work I would have thought!
    Mar 2016
    IRAN
    181
    4
    Re: What is this ?
    Dear RANGER1,
    Thanks for your reply. I found my question answer, It is "EDUCTOR", With this mechanism compressor sucks oil that collected in end of compressor and takes it to sump.
    Photo of educator and how it works at below :
    Mar 2016
    IRAN
    181
    4
    Re: What is this ?
    Quote Originally Posted by Glenn Moore View Post
    Yes, Exactly.
    2,714
    30
    Re: What is this ?
    Quote Originally Posted by A.Mortezania View Post
    Yes, Exactly.
    In this situation with eductor, do you know where the pressure comes from to make it work on input port?
    Sump must be very “open” or large equalisation port to suction of compressor as not to pressurise sump.
    Learn something new every day, hopefully
