    Apr 2017
    Canada
    1
    Manual expansion valve
    I知 looking to construct my own refrig system using r404. I want to be able to change the temperature of the evap coil. I知 looking to to vary between-30c and -50c. I知 prob going to use a compressor between 1/3 and 2/3 hp.
    Is there something on the market that exists? Does it have to be packless? I could use a cap tube, but it would be a lot of guess work as I壇 like to use salvaged parts.
    Thanks!
    1001yos
    11,192
    Re: Manual expansion valve
    I would suggest an electronic expansion valve but it might not be cost effective.
    Although you might be able to salvage an EEV from a modern AC unit you will have to either invest in a controller for it or build your own.
    49
    3,874
    Have a look for a suitable 'Automatic Expansion Valve', they control the flow to the evaporator by maintaining a set pressure which you can adjust maunally.
