    Apr 2001
    79
    5,071
    35
    Gree Multi over cooling
    A friend has just installed a Gree Multi to service two rooms. One of the rooms seems to be working normally while the other room over cools and freezes the indoor coil. No error codes. Any idea what might cause this?
    Feb 2008
    504
    Re: Gree Multi over cooling
    have you checked the interconnecting wiring is not crossed
    Apr 2001
    79
    5,071
    35
    I will definitely check that. Thanks.
    Apr 2001
    79
    5,071
    35
    You were right. The wires were crossed. We swapped them back and everything works. Thanks.
    Feb 2008
    504
    you shod always run each unit independently on first start up this way you will no the piping and wiring are correct
