    Mar 2016
    IRAN
    182
    9
    Screw compressor
    Hi friends,
    I have a question. At photo below (photo of Bitzer screw compressor + oil separator + oil cooler) there is a bypass line that links discharge to suction via solenoid valve (No. 12).
    While we use this bypass line in screw systems ?
    Thanks for your helps in advance.
    11,025
    Re: Screw compressor
    That picture is from the Bitzer Application Manual and shows the 'standstill bypass'.
    If you go to page 30 of that manual you will find the description of that bypass.
    Mar 2016
    IRAN
    182
    9
    Thanks a lot Brian_UK, I check it.
