    Feb 2005
    New Zealand
    43
    Tools for measuring flow water flow rates through binder access ports
    Any recommendations on a tool to use for measuring flow rates for water + glycol hydronic systems much appreciated
    11,025
    Re: Tools for measuring flow water flow rates through binder access ports
    It all depends.
    Do you have commissioning valve stations, orifice plates or simply pressure test points across components with known pressure drops.
    Commissioning valve manufacturers may have dedicated test kits or you may be able to get a test kit that is calibrated for many manufacturers.
    For simple pressure drops you could use a simple water manometer.
    Wrong country I know but just an indicator ...
    https://www.bsria.co.uk/instrument/s...oning-systems/
    Jun 2011
    Australia
    44
    336
    Feb 2008
    505
    you can buy ultrasonic flow meters on eBay that clamp to the outside of the pipes
    Feb 2008
    505
    comtronic is a good flow meter for binder points
    Feb 2005
    New Zealand
    43
    Thanks for all the great options, have emailed the rental company for the ta scope as they are Ta valves.
    Very interested in comtronic and ultrasonic so will read up on them tonight. Thanks for all your help
    Mar 2006
    Lancashire
    1,859
    28
    The comdronic is a great meter. It gives the Kvs of most manufacturer commissioning sets, valves, orrifice plates. Nice and quick when on site.
    Some say not as accurate as a water box though.
    Marc
