    Jun 2006
    alabama
    leaking fridge evaporator
    Hi there!
    I was accidentally punched the fridge evaporator. So what's the next step should I do to fix the problem.
    If possible I don't want to purchase the new one evaporator. Please advise me.
    Thanks.
    Sep 2003
    54
    21
    Re: leaking fridge evaporator
    Clean area around pierce with wire wool. Then wipe clean with solvent you get with epoxy resin needed to repair joint. Fit vac pump and run system in a very slight vac, apply resin and leave to set. Once set replace drier, pressure test, re-vac system and charge with refrigerant gass.
    I choose to run very slight vac as it draws poxy and gives a very good seal, never had a leak yet, but rember the vac must be slight you don't wanna suck the epoxy around the evap.
    Lucas
    Jun 2006
    alabama
    thanks Lucas
    Apr 2001
    2,099
    27
    Unless its your fridge, and you want to have a go, fine.
    If its a customers...........dont bother
  1. copper evaporator
    By nic0 in forum Technical Discussions
    Last Post: 26-08-2011, 11:24 PM
  2. Home-made fridge
    By ChrisKlinger in forum Trouble Shooting
    Last Post: 26-01-2010, 07:23 PM
  3. Change evaporator
    By tralex in forum Fundamentals
    Last Post: 29-12-2005, 07:53 PM
  4. help- my bar fridge is wacko?!
    By ben in forum Trouble Shooting
    Last Post: 25-01-2002, 12:06 AM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
