Results 1 to 1 of 1
Thread: Automotive Service Valve Leak
Threaded View
25-01-2019, 02:56 AM #1
After successful compressor replacement and refrigerant swap, from R134a replacement with (40%) proprietary R290/R600a blend, we have discovered that both service valves are leaking.
Renewing both schrader valves, within the push-fit service valve fittings, did not seem to help. Over-tightening the schrader valves improved the situation significantly, however a very slow leak remained.
Unfortunately the push-fit service valve caps are plastic, with a thread matching the schrader valve, and do not hold (much) pressure.
Any advice on the best way forward would be warmly welcomed.
