Results 1 to 10 of 10
Thread: 30gtn
31-12-2018, 03:36 AM #1
30gtn
Good morning All.
Can someone assist please.
I have this 30gtn carrier chiller, it trips breaker immediately it wanted to start running.
I have checked all Fan Motor and Compressor for Short and they are ok.
Only one compressor is bad and I have disconnected it from the system.
All relays have been checked.
Please can someone assist me on what to do. Thanks
31-12-2018, 09:41 AM #2
Re: 30gtn
Your Earlier posts say it all Charles.
Good day Engineers
Please I need urgent help.
I'm not that grounded in electrical.
I connected a compressor today and the result was a blast.. Breakers trip and compressor burnt.
what you are now getting I assume?
Is as a direct result of your previous actions.
Knowing when to stop is sometimes as important as knowing what to do.
Enlist the help of local more knowledgeable colleagues.
GrizzlyLast edited by Grizzly; 31-12-2018 at 10:26 AM.
31-12-2018, 05:03 PM #3
Re: 30gtn
Grizzly good pm,
Though I'm not grounded in electrical but I understand it because I read and learn everyday.
I only asked questions because I want to know more.
I was expecting someone who has experience same problem to tell me the possible causes.
31-12-2018, 11:24 PM #4
Re: 30gtn
You've checked for shorts but have you checked the starters?
Is the supply voltage correct and strong enough?
Switch off/remove fuses to the compressors etc. Start up and recheck the starters for continuity.Brian - Newton Abbot, Devon, UK
01-01-2019, 06:21 PM #5
Re: 30gtn
Get hold of Mandola's in Lagos as the local Carrier dealer they should be able to solve this problem. You seem out if your depth.
Gibbo.
03-01-2019, 08:09 PM #6
Re: 30gtn
Thanks a lot Mr Brian _UK
01-01-2019, 06:22 PM #7
Re: 30gtn
Mandilas in Lagos.
03-01-2019, 08:12 PM #8
Re: 30gtn
Thanks Mr Gibbo, I'm a staff of Mandilas Enterprises Limited. Carrier Division, Lagos
01-01-2019, 07:43 PM #9
Re: 30gtn
Check that your electric supply has 3 phases.
You might have lost one when it tripped the first time.
03-01-2019, 08:13 PM #10
Re: 30gtn
Chemi cool thanks a lot
