    Jan 2014
    India
    27
    5
    Post Bitzer reciprocating compressor overhauling period
    What is the general overhauling period for Bitzer make double stage hermi-sealed compressor. Refrigerant is R404A, Oil is BSE32. Let assume all parameters are with in limit while working.
    Sep 2003
    ISRAEL
    67
    4,196
    40
    Re: Bitzer reciprocating compressor overhauling period
    As long that it running OK, do not touch it. Unless you are really board
    Sep 2009
    Iran
    61
    496
    13
    if every parameters in the compressor is OK .
    then you have short gas in your system
    in 2 stage system your carter is a intermideat.
    sightglass in both liquid line and intermediate line should be full
    also check CIC is working
    Jun 2017
    Shiraz
    1
    Bitzer compressor 6G-34Y needs use Cic or don't need for R404a.
    Tanks
