    Dec 2005
    Cheshire
    33
    259
    Mitsubishi PUHZ-P100VHA3 U9 Fault
    Hi Guys,
    Briefly looked at this last week - seems to run ok on cooling. Indoor is PLA-RP100BA cassette.
    Heating - gets past the preheat for about 5mins then goes off on a U9 Fault.
    Seems to not be ramping up to full speed. Pipe sensor (I think this the liquid 3/8) on remote (PAR-21) gets to 39/40deg max.
    I did manage the get it to run full speed but only briefly on test mode.
    Checked there is definitely 240V at the mains in connection.
    Before I return, are there any obvious/common things I need to check?
    Service manual is showing a few connections to check.
    Thanks,
    Dec 2008
    514
    Re: Mitsubishi PUHZ-P100VHA3 U9 Fault
    U9 is often associated with abnormal voltage in the inverter. Suggest you phone the Mitsubishi Helpdesk from the site and they will give advice as to which terminals to check the voltages at.
    Mar 2011
    Dublin
    44
    Dec 2005
    Cheshire
    33
    259
    Thanks both
    Mar 2011
    Dublin
    44
    No prob, if you Google the Par 21 controller is shows you where to go once you get the request code. Let us know how you get on.
