    Sep 2009
    7
    Samsung RFG23UERS Side by Side
    Does anyone know why the RFG23UERS does not make ice and give not enough pressure to give sufficient water, the waterpressure at the tap (behind the fridge) is ok?
    11,192
    Re: Samsung RFG23UERS Side by Side
    You say that the water pressure is okay but what is the pressure with all taps closed and with a tap open?
    Sep 2009
    7
    It is a newly build house, so everything works like it should.
    Feb 2008
    505
    is there a filter in the water valve
    11,192
    Quote Originally Posted by michel_engelen View Post
    Except the refrigerator.
    Without test readings no answers can be given. Good luck with your problem.
