    Adelaide , Australia
    192
    14
    Wink scotsman ac176 as - fault during harvest
    Hey all , Its been a while but I have a Scotsman AC176 as air cooled icemaker .
    It makes ice no problem but fails or goes out on HIGH CONDENSER temp during harvest .
    ( yes Condenser is clean ) I tried switching it to water cooled to trick it but still failed ?
    Ordered new probes ....that was worse it actually didnt even run with them , supplier couldnt tell why but took my $250 for two probes . I can return the probes but Im told the fault is with the PCB , another $480 jesus ! So it adding up and yes I can recover all my money once I fix it .
    Wondering if anyone has the resistances for the probes tempted to have a fiddle ? instead of buying new PCB .
    60% of the time it works everytime.
    Jun 2011
    Australia
    331
    Re: scotsman ac176 as - fault during harvest
    Hiya,
    It is a different model but resistance should be same,
    https://www.scotsman-ice.com/service...g/306456pr.pdf
    Page 53 says
    32,649 ohms @ 32F (0 Celsius)
    Happy tinkering
    Mankind does not know why Coffee make us poop..
    https://m.youtube.com/watch?v=U8Fqyyv16SM
    Jun 2011
    Australia
    331
    And,
    http://www.refmech.com/wp-content/up...ice-manual.pdf
    Page 132 shows Full Resistance Chart (albeit Fahrenheit)
Tags for this Thread
