    Dec 2011
    spain
    58
    35
    Room temp display on ducted system
    I've installed a ducted system in an apartment. The manufacturer is Giatsu which is Spanish based. The wired control display only shows SET temp and not ROOM temp. I suspect there is a switch setting on the PCB which changes where the temp is measured and think this just needs changing. Unfortunately, Giatsu is proving difficult to contact, however the PCB is exactly the same as a Hisense ducted and so I'm presuming the switch will be similar. Does anyone know which switch button to press?
    70
    10,643
    52
    Re: Room temp display on ducted system
    Have you contacted Hisense yet?
