    Dec 2004
    U.K
    55
    518
    21
    Carrier WT sensors
    Does anybody know what the score is with Carrier WT sensors as fitted to Supra's etc.
    Why do they fail so often???????????
    Mar 2005
    Austraia
    48
    Re: Carrier WT sensors
    Quote Originally Posted by djbe
    Hi no .............I haven't had to fit them that often over the years..............but now I have stated this.................thats all I will be doing next week
    Martin
    Dec 2004
    U.K
    55
    518
    21
    Iv'e had some units that have had 2 or 3 in a relatively short period of time.
    Maybe it has just been the luck of the draw with the Supras that I have worked on. You always tend to notice the bad ones but forget about the others that don't cause problems.
    regards,djbe.
    Jul 2005
    55
    10
    Hi I used to look after about 25 supra's and a lot of R70/90's some years back from memory the sensor is fitted at the back of the engine by the exhaust (the problem) There used to be a blank by the thermostat, I used to fit the new one there and leave the old one in place and keep hold of the blank as they come in handy
    Dec 2004
    U.K
    55
    518
    21
    That would explain it then.
    I have noticed that Carrier now fit the sensor into the thermostat housing so they must have realised their mistake.
    Thanks Seacold, another mystery solved
  1. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  2. Carrier Water Chillers
    By Latte in forum Air Conditioning
    Last Post: 11-10-2008, 08:43 PM
  3. Carrier chiller oil migration
    By lowtech in forum Industrial
    Last Post: 30-04-2006, 04:11 PM
  4. carrier remote
    By superswill in forum Trouble Shooting
    Last Post: 26-04-2006, 09:17 PM
  5. Required Control Wiring 50dp-020-910 Carrier
    By altaf22m in forum Air Conditioning
    Last Post: 08-08-2005, 06:08 PM
