Thread: Legal or no ?
    Dec 2010
    devon
    48
    802
    Legal or no ?
    Went to a site today where the inhouse engineer has starting swapping condensor fans to sea if he could get it running
    The gent has no f gas or refrigeration background can he legally work on a 7 kws split cassette i admit he does not seem to touch the refrigerant side of things that i no off but he has been playing electrical wise many thanks charlie
    71
    10,740
    Re: Legal or no ?
    I would say no, he should not be working on the equipment.
    Start reading here..... lots of angles but same answer.
    https://www.gov.uk/guidance/qualific...ntaining-f-gas
    Feb 2009
    telford
    2,097
    28
    Re: Legal or no ?
    So if I call a sparky in he cannot touch it even if he certs,forgive me but he is more qualified than me in electrics ? or have i misread?
    5,144
    44
    Re: Legal or no ?
    Looking at the link Brian posted it is not clear if the Catagory 1 cert covers Automotive. Does Automotive need a seperate cert?
    I'm back on the Pale
    Nov 2006
    710
    Re: Legal or no ?
    I queried this type of activity with REFCOM and they simply stated the part of the legislation which says yes he can ( I can find in a previous email if you would like) fan motors filters and any non evasive refrigerant circuit work
    Oct 2008
    newbury
    1,411
    Re: Legal or no ?
    Quote Originally Posted by Quality View Post
    I always assumed you could touch the non invasive side
    similar to gassafe and boiler work. You can legally change PCB's and switches etc provided it's not part of the gas side and -if I remember correctly-nor the flue fan which is also 'gassafe' territory
    Y
    ou must be qualified to work on systems and equipment containing fluorinated greenhouse gases (F gas) that the EU regulates.
    Stationary refrigeration and air conditioning (SRAC) systems, including heat pump systems
    To work on these systems you must be qualified if you want to:
    install new systems
    service and maintain them
    check leaks
    recover refrigerant gases
    decommission and dispose of old systems
    although no/2 would seem to suggest otherwise...? A corner shop would probably argue/ignore but a blue chip facilities manager might err on the side of caution.
