    Jun 2017
    palestine
    29
    4
    Unhappy Samsung aqv12ewcn E464 IPM over current
    Hi everyone,
    i was looking for service manual for this unit aqv12ewcn and i didn't get anything.
    the outside unit work for 30 sec and turn off , also the red light is blinking.
    i have checked most of the component of the PCB but i found fault resistor R105 6.8k near (coil) called PT (sensor as i think ) and i replace it , the shunt resistor is working probably (its give me short circuit and 0.01 ohm).
    But i suspect the capacitors (there is no visual explode or any damage ) how should i test them ?
    please advise
    Jun 2017
    palestine
    29
    4
    Re: Samsung aqv12ewcn E464 IPM over current
    the outdoor unit is AQV12EWCXTEV
    Aug 2007
    Russia
    140
    22
