    Feb 2015
    14
    Daikin E5 Error and Weird Issue.
    Model - RXYMQ48PVJU
    I found this unit with a grounded compressor and burned PCB. Replaced both and initiated a testrun followed by a shutdown on code E5. I checked the stopvalves, incoming power, and all connections including compressor wiring for correct orientation. I also checked to make sure the refrigerant was equalized.
    Here's what happens:
    I have an amp meter clamped on one of the lines. The unit will initiate compressor start and will drive to about 5 amps go up to about 18 amps, ramp back down to about 5 amps, and back up again. This all happens within 5-10 seconds. Unit will initiate a slight delay and start the process over again. Every time the compressor attempts to start, it will visibly shudder.
    I don't have an inverter checker, however I used Mode 2 28 to test the phase balance. All measured about 9 V.A.C. (It seems kinda low but Daikin says okay).
    I really can't believe a new compressor would be DOA, but I suppose it's possible.
    Any ideas or other things to check?
    11,025
    Re: Daikin E5 Error and Weird Issue.
    I assume the burnt PCB was the inverter pcb.
    Have you checked all of the tests on the pcb as detailed in the service manual? https://bit.ly/2sIhR3x
    5,668
    Did you make sure to reconnect the compressor terminals as you found them?
    You may have phase connections incorrect
    Feb 2015
    14
    Thought I should follow up with this.
    I checked the Inverter board as per the manual. I believe the P + N wires are the same as the test points C+ & C- on the board?
    Board all checked out. Replaced compressor and started right up. Probably very rare, but the new out of box compressor was bad.
    I purchased an EDC inverter checker, but could only get three of the leds to light up on this particular unit. I then used it on a known good unit and none of the leds lit up at all. Since it's 3 phase AC coming out, I assume the test leads shouldn't matter in how they are connected. The only thing I can think of is when the system is put into transistor test mode or started on a regular cooling cycle, the voltage is too low to fire off the leds. I know the tester has internal resistors in the circuit. Disappointed this tool didn't work for me.
    Aug 2007
    Russia
    140
    22
    3 phase AC coming out you can check with the True RMS multi meter.
    11,025
    Thanks for the update RJ.
