    Feb 2017
    RUSSIA
    2
    York Ycaab 150 standard control panel change coolant
    Hi guys! The York Ycaab 150 chiller has a standard control panel. There was a failure: the parameter "coolant" was "gligol" became "water". Because of this, the protection turns off the unit for freezing. Please tell me how to fix it back.
    ireland
    1,452
    Re: York Ycaab 150 standard control panel change coolant
    Can you access the parameter list? If so change it to glycol and then adjust the antifreezer setpoint.
    Feb 2017
    RUSSIA
    2
    Unfortunately, there is no such information in the service book. Therefore, I appeal to the guru to help me.
    Tell me if you know the purpose of these switches
    ireland
    1,452
    Unfortunately i don't have any service or setting info on that model, hopefully someone else may have.
