    Jan 2017
    United Kingdom
    38
    Advice on cheapest options for potential client
    I have gone to have a quick look at something the compressor has gone in a 10kw cassette system it's a daikin it's an older model and it's 410A now the price of the gas now is ridiculous so I'm debating whether it's worth trying to replace the whole outdoor unit instead of the compressor and the inverter board or get a multisplit system and 2 wall mounted units its in a newsagents but it's about 60 sq meters hence thr 10kw cassette in the middle of it.
    Where is a good place to order systems at a reasonable price.
    And also has anyone used euro refrigerants.com as they sell 410A for about 400 euros and deliver to the UK and also do refill service. Alot cheaper than UK prices. Unsure of quality though cannot seem to find any reviews. Thanks for the help guys and girls.
    ireland
    48
    1,329
    35
    Re: Advice on cheapest options for potential client
    Euro refrigerants as far as i can tell are legit, i think they require your fgas or refcom cert to supply. From what i can see all the wholesalers are carrying splits, Logicool, FSW, Hawco etc, customer is going to pay more for a new install but you could sweeten it with extended warranty also if you can, confirm why original compressor went, check the install carefully if you're planning on reusing pipe work, and confirm unit was sized correctly.
    Jan 2017
    United Kingdom
    38
    I doubt he will go for it in the end as the cheapest multi split for the room size I can find is 2k alone for a 60m sq room. The only really cheap ones are units I wouldn't touch as no ones heard of. One called electric iq has 2 12000 btu indoor units and a 24000 capable outdoor for under a grand. No way on earth will it work when it's half the price of one of the known cheaper brands haha.
    What are some cheaper air conditioners that work like budget ones then I can offer to option of something like a toshiba or mitsubishi or something a bit cheap that still does the job.
    ireland
    48
    1,329
    35
    Fugitsu, Panasonic,Hitachi, good gear, reasonable prices.
    44
    3,809
    Price to do the job properly, its the customers choice to decide if its worth it.
    May 2012
    54
    1,370
    30
    Ben you have a problem that all good engineers have to face.
    You want the work and you know the customer doesn't want to pay
    so you try your best to find a compromise that results in you getting
    the work.
    You also have to protect your name, you could install a cheap system
    and for a while the customer might get what he thinks he wants but
    what happens when it fails and proves to be a load of crap.
    Or you can stand your ground, give a quote for a system that
    will be reliable, guaranteed and long term value for money.
    You might not get the job and the customer might get the work
    from someone else.
    Hard decision and it's you alone who can decide what is more important
    to you.
    Rob
    Feb 2005
    United Kingdom
    48
    56
    Logicool good for splits. They will give you decent support. Don't touch R410a from outside the UK. It isn't worth it.
    Dec 2008
    Los Angeles
    32
    Cheap work is not good, good work is not cheap. Put it on your business cards, trucks, website, etc.
    Dec 2008
    Los Angeles
    32
    Least expensive, not cheap. Here endeth thy lesson for the day.
