    May 2012
    59
    1,528
    Change the pressure - Change the temperature.
    Re: Change the pressure - Change the temperature.
    Temperature is hard to read.
    May 2012
    59
    1,528
    What's the matter Brian?
    Are you not familiar with the new fangled temperature range called Celsius I could have done it in Fahrenheit
    Rob
    Feb 2009
    telford
    2,090
    33
    Centigrade ha ha
    No Rob, I simply meant that I couldn't see the display on your thermometer.
    [Edit] Reset the brightness level on my tablet, bit readable now. Ooops.
    May 2012
    59
    1,528
    So your good with modern metric scales just not with tablets
    In truth when I show it on a big screen the temp is hard to see sometimes
    and I always put it down to the projector bulb colour but I think you are right
    if I did it again I'd use a different display.
    I did do it once with a probe through the bung in the water but gave up after
    the probe failed, I don't think it like being in a vacuum and in water
    Rob
