Results 1 to 12 of 12
    4,698
    When to Oil or grease Gaskets?
    Just a general question really, aimed at the newer trained Guys as much as us old timers.
    I have a colleague who insists on greasing gaskets wherever he can.
    I tend to use Silicone Grease nowadays, but don't use it all the time.
    What's everyone take on this?
    Cheers Grizzly
    hookster's Avatar
    Apr 2007
    Hampshire
    438
    32
    Re: When to Oil or grease Gaskets?
    I use silicone grease for o-rings, leak-lock on gaskets and fittings for gas tight sealing, copper grease on high temperature gaskets or a molybdenum grease.
    I would use grease on most gaskets for a few reasons.
    One to hold in position & two to keep suple for easy removal next time like on a compressor.
    If not greased expect to have to chisel off due to being baked on, like a head gasket.
    Most OEM would say oil gasket.
    Others may say it is contamination.
    Years ago graphite grease was or can be used & gaskets were reused.
    Some gaskets are graphite impregnated like Danfoss, which can be reused if not torn
    Do whatever works for you, some don’t know why they do it, just how they were shown.
    May 2012
    59
    1,528
    Copper grease where required and then I use the oil from the system.
    If a gasket is proving awkward to hold in place until it is closed up I
    do use a bit of silicone grease, but rarely.
    Rob
    So copper grease on ammonia, is it like anti-seize or something like that?
    Whatever the case use it sparingly.
    Sep 2003
    ISRAEL
    72
    4,248
    I use the compressor oil or nylog.
    4,698
    Hi Guys!
    Copper Grease on Ammonia.
    I know from doing vehicle Maintenance the Copper grease is excellent on High temp stuff and its anti seize properties are used Where Brake calipers are concerned.
    But I thought Copper gets eaten by Ammonia?
    May 2012
    59
    1,528
    No not on Ammonia
    I mostly use the comp oil, that is what fingers are for,
    now how do you spell dermatitis...............
    Rob
    Croatia
    68
    2,263
    generally compressor oil ...
    grease in small amount only if need to keep gasket in place during re-installation ...
    Best regards, Josip
    Jul 2006
    73
    865
    I always used compressor oil on the gaskets.
    Anti-seize on flanges or something like Vilter head gaskets. Definitely go with Nickel base anti-seize on NH3.
    I did have an oil analysis done on a Frick screw. Came up with Nickel. The only explanation we could come up with was anti-seize on the gaskets.
    Aug 2007
    Adelaide Australia
    70
    562
    Hi Grizzly
    I have always used grease on gaskets for the reasons Ranger stated.
    Years ago it was graphite grease but now would use moly grease but always sparingly.
    I put the grease on the gasket not the machine surface. I have seen people paint it on with a brush and it gets in the bolt holes, eventually the holes fill with grease and instead of pulling down on the gasket the bolt pulls up on the grease when torqued, result leaking joint.
    I have used silicone grease on O rings only.
    Paul
    Born to fish, forced to work
    3,856
    Compressor oil, or nylog, but have used hylomar blue on a difficult to seal receiver gasket before.
